Easy How To X2 and SX Water Box Drilling
Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 158
    Aug 2008
    CT
    Ok here is a Easy How to for X2 Water Box drilling!
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Aug 2008
    CT
    Re: Easy How To X2 and SX Water Box Drilling
    Ttt
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    PWCToday.com Is My Home Away From Home 10mm's Avatar
    Apr 2009
    MN
    Just out of curiosity what does this do?
    Aug 2008
    CT
    Increased flow. A drilled stock box will make the same or more power than a aftermarket water box and won't be as loud and only cost you time and a drill bit.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Apr 2009
    MN
    Quote Originally Posted by Twinturbostang View Post
    hmm, good info.
    PWCToday Newbie VTJoe79's Avatar
    Jun 2010
    Uncasville, CT
    Or if you're stupid and don't take your time, the cost of a second drill bit once you destroy the first one.
    I'd recommend using some sort of lubricant while drilling, those waterboxes are freakin hard
    1990 X2 - Drilled Waterbox, Bolted steering Mod, oil pump delete, 38mm, chopped hull. In the Works: 15.5 skat trak, hydro turf, decals, etc ....
    PWCToday Newbie crzylx's Avatar
    Jul 2010
    Connecticut
    I'll be doing this tomorrow on my X2. Thanks for the free info guys.
    1990 X2 - Stock
    1988 X2- Modded (wife's ski)
    Frequent Poster miahs x2's Avatar
    Jul 2010
    so cal
    I'm not sure if I have a stock water box or not?how do I tell? I bought the ski used and it does have a few aftermarket parts
    Top Dog x2jess's Avatar
    socal
    If it's stainless it's probably stock. All the aftermarket ones I've seem are aluminum. Post up some pics and I'm sure someone will be able to ID it. Or you have my email, send some pics.
    Jul 2010
    so cal
    Cool thanks jesse,I'm at work right now so when I get home ill email u a picture
