pipes performance on the dyno
    Feb 2006
    ITALY
    Hi Bill,
    my request is made for personal information only!!
    The motor is a twin 1050 SS with the same setup (carbs, Mpem, etc). Which ex. system makes the most top power and what is the hp difference between:
    a) Single pipe Coffmans system.
    b) Double Factory Pipe system.
    From what I know and this is I think common knowledge a multicylinder two stroke equipped with a pipe per cylinder delivers the most power.
    Speaking instead with some tuners here in Europe they stated that in the case of the Rotax BB twins the differences between a single pipe system and a double one are not very noticeable!!
    What is your point of view?
    Michele
    Feb 2004
    Glendora, California
    Re: pipes performance on the dyno
    Personal information? On a open website? LOL!
    If your Miller 1050 is properly ported for twin pipes it can produce more HP with a twin pipe setup. But if it was ported for a Coffman pipe, it will not produce more HP with twin pipes.
    Feb 2006
    ITALY
    Hi Bill,
    Maybe that I have expressed myself in the wrong way with the words "personal information".
    I wanted only to say that the requested infos were only to increase my personal technical knowledge about the problem!! I have absolutely
    no problems to share infos with everybody here in the forum.
    You stated that each pipe needs its specific porting to give optimum performance and this is out of discussion for a SS package in which you are permitted to modify the porting.
    But if I work in a Limited setup where porting can't be changed which pipe pipe system gives the most power output?
    Thank you
    MIchele
    Sep 2005
    Loganville, Georgia
    Bill,
    Also, can a 1050 ported set of cylinders for a coffman be modified to the run the twin setup?
    Feb 2004
    Michelle,
    On a unported limited race motor, the FPP long chamber twin pipes will probably produce about 10 hp more than the Coffman pipe. There will be a substaintial increase in the midrange power for accelleration, with a bit more HP at the very top end.
    I suggest that if you are a really good tuner, you can get good results with the twin pipes, but most guys will not necessarily be all that much better off than if they ran the easier to tune Coffman setup. Some would even say that the Coffman setup is better, especially if they have modified their exhaust manifold with some creative porting and milling equiptment.
    An example of the power differences between the C pipe and the twin pipes is with the oem 951 engines. A stock RXX was rated 160 HP from the factory. That is an increase of 30 HP over stock 947's that make 130 hp.
    A coffman exhaust on an otherwise stock 974 makes about 150 HP, a gain of 20 hp.
    Feb 2004
    Quote Originally Posted by bonus
    Bill,
    Yes we do upgraded porting to make a Coffman ported clyinder work with the twin pipes.
    Resident Guru mandriva's Avatar
    Sep 2009
    montreal,quebec
    Long live for great info..thank you! This post answer my question
    Rossier 7250 rpm
    110 mid pipe/200 stinger
    185 psi/Head 41cc/43squish
    Solas concord 15/23
