Results 1 to 9 of 9
Thread: jet ski lift
    PWCToday Regular spanky88's Avatar
    Dec 2006
    Miami ,fl
    jet ski lift
    does anyone know of a lift or way of lifting a jet ski off a trailer ...i have three skies on a double trailer and a single one...i would like to which skies around with out having to take both trailers over to the ramp and paying two ramp fees just to move things around
    PWCToday Guru tominaustin's Avatar
    Jan 2007
    Austin, Texas
    Re: jet ski lift
    I use a cherry-picker I got from Harbor Freight. It's the foldup 2-ton type. Works great and you can fold up the legs when you're done. Rolls easily on concrete or asphalt.
    With a couple of motorcycle tie-down straps it works perfect on older skis.
    If you've got a big ski, check ebay for the lifting straps.
    Hope that helps.
    TomInAustin
    Top Dog 800wildcat's Avatar
    Mar 2004
    Ripon, WI
    Re: jet ski lift
    Can use a cart. Have seen a relatively cheap but doable one for a garage made from PVC bolted to a wood base with caster wheels. Another way is to make one from auto exhaust tubing, you could get a custom exhaust place to do the 4 bends and 4 welds. You may be able to see it well enough in the attached photos to get the idea.
    '99 STX 1100/1200 triple pipe, 48 NOVI's, Cold Fusion head, ported, Kaw race ign, Skat pump, drop nozzle, light seat, carbon hood; '97 STX 1100 Cold Fusion head, ported, modded stock exhaust, timing advance; '86 X2 Westcoast pipe, WC 180 psi head, 38 dual Mikunis, ported, MSD; '87 X2 Kerker manifold, PJS pipe, PJS 190 psi head, dual 38's; '87 X2 stock w/ 44 carb, pontoons; '89 SX 650; '95 X2 750 project; Johnny O's supercharger; 650 MRD fuel injection, must sell enough to keep wife happy.
    Dec 2006
    Miami ,fl
    Re: jet ski lift
    i like the cart but how do ya get it off a trailer and on to it...cherry picker does sound like a good idea
    PWCToday.com Is My Home Away From Home professor9's Avatar
    Nov 2005
    Cranberry Township, PA
    Re: jet ski lift
    I know the couches you are wanting to move are a bit heavier than what I have, but what I do is hook my trailer up to my truck, then slide my TS back onto a cart.
    Take a look at Davit lifts - they may give you an idea or two. Some sort of strap lift, then use a hoist or chain fall to lift.
    I'd say get a cart with wheels and then you can always have one on the cart. Prof
    Frequent Poster seadoo951's Avatar
    manhasset
    Re: jet ski lift
    Just get the cart and push them off the trailer on to the cart. I do it with my RX and XP which both weigh over 500 lbs. Its not that hard.
    I dream skis devastator's Avatar
    Jun 2005
    Manhattan, NY
    Regards,
    Ray
    2006 KAWASAKI STX 15F
    Top Dog gj_fx1's Avatar
    Sep 2002
    dayton
    Re: jet ski lift
    I use two of these attached to the rafters in the garage:
    http://www.harborfreight.com/cpi/cta...emnumber=30329
    ..with half-inch rope through bow and stern eyes.
    Note the cable pullers are "not for lifting" - just take the weight off so you can slide the trailer out and your stand under.
    Dec 2006
    Miami ,fl
    Re: jet ski lift
    thanks for all the ideas...i like the cart cus lifting my 800 lb 06' gtx sounds kinda scary ....i think im gonna use a cart to slide my gtx around and use the cherry picker for the xp and my other gtx (both 96')
