Results 1 to 6 of 6
    PWCToday Regular mccann316's Avatar
    Berne
    Testing SLTX stator?
    Can anyone tell me how to test an SLTX 1050 stator, 1997. It has no spark, all switches and CDI has been eliminated along with connections. Is there an easy way to test with an OHM meter? Anyone know what the readings should be between the different color wires? Thanks.
    PWCToday.com Is My Home Away From Home ZMANN's Avatar
    Jan 2006
    AZ
    Re: Testing SLTX stator?
    HI! How did you eliminate the CDI? test with another? anyway jump over to greenhulk.net and in the Polaris section they have the testing values! Z
    http://www.pwctoday.com/image.php?type=sigpic&userid=15348&dateline=1238301767
    Berne
    Yes, I have another running 97 SLTX 1050 that I tried the CDI box off of and still no spark. Thanks for the help I will check out that site...
    Berne
    And it is too much work to do the same with the stator which is why I am trying to test it...
    Resident Guru 785 lugs's Avatar
    Feb 2005
    chicago il.
    go to greenhulk .net they have it in there tech section . i have a few new stators if you need one .bob
    Jan 2006
    AZ
    Testing a stator is easy in the craft! you can't test it 100 percent but the common issues will show! hey lugs how much for a stator?Z
