Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    PWCToday Newbie T-townjt's Avatar
    Del Rio Texas
    Help! 650sx Handlepole spring installation?????
    I'm putting the handle pole back on post bushing install. I frukced up and forgot to check the exact placement of the spring. I know the rubber coated piece comes forward towards the engine, but does the other end tuck in behind the fiberglass crosspiece at the front of the pole, or does it simply set against the top closer to the handlebars?? 1993 sx650. This is the stock spring, not the aftermarket piece that bolt's on seperately.
    Del Rio Texas
    Re: Help! 650sx Handlepole spring installation?????
    anyone have any good pictures of the assembly? Good places to find online guides?
    Frequent Poster adam.van's Avatar
    May 2006
    North Jersey
    Hope this helps.
    '98 XL 760
    '87 650 SX
    '81 Glastron SSV-176 Johnson 115
    May 2006
    North Jersey
    Ok just realized mine is an aftermarket type. Here is from the kawasaki parts diagram.
    '98 XL 760
    '87 650 SX
    Del Rio Texas
    Adam, thanks for the great pictures. I have an aftermarket spring kind of like yours. Should i just leave that stock one off? I see you don't have one in your picture.
    May 2006
    North Jersey
    You could leave it off, although my pole feels heavy compared to an 05 SXR which is the only thing I can compare it to. Mine might just be worn out. Also it looks like the 87 650 SX (which I have) did not have a stock spring. See how it feels, you could always add it later or replace the aftermarket one.
    '98 XL 760
    '87 650 SX
    Does anybody know if you have to remove the hand pole to install an aftermarket spring on a 650sx? I am trying to install one myself right now, used with no instructions, and can't seem to figure out how to do it w/o pulling the pole. The spring still hits it hard enough with the pole all the way up that you can't get the bolts back in because they're at a 45 degree angle and will obviously strip. Any help would be great as I was hoping to try it out tommorow morning.
    PWCToday Guru KaosFreestyle's Avatar
    Jun 2003
    Wisconsin
    No you do not have too. Do you have the little L-shaped tool holding the pole up?
    Quote Originally Posted by KaosFreestyle
    The pole is held up with the pin and my gf is pulling it forward to take up that extra 1/4" of play. I don't see any way to do it without pulling the pole, installing the spring, pressing the pole back against the spring and then slipping the bolt thru. What am I missing?
    I'm getting frustrated here. I just finsihed rebuilding a 4 stroke dirtbike(thumper) with no problems, but yet can't get this stupid spring installed.
    Jul 2007
    NY
    ive got the same problem i just said forget it
    some 650s (2 modded)
    polaris sl750 lol
