Seadoo HX Pics post em.... - Page 3
Page 3 of 34 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 336
    Re: Seadoo HX Pics post em....
    Its not looking good,not that I dont want to go....Maybe
    Again a lot of $ for no return,maybe if it was a little closer it tough for us east coasters to go to WF every year.
    Here are some pics of a HX that I put a 800 in,I have since sold the motor a made this my backup ski...
    I dream skis swiftman's Avatar
    Sep 2005
    Wa state
    Heres mine...Ill post a better pic of the ski tommorow this doesnt do the paint job justice...
    Motor:
    Msd Ignition,Total loss with RAD flywheel(non-charging)/dual pickup cover
    All the add-ons to the ignition
    185 psi compression perfectly equal both pistons
    Rossier race Pipe with MSD water injection
    44mm Novi's spigot mounted on Westcoast 15* intake
    stock rotary valve grinded to clear porting
    Ported cases and intake sleeve/exhaust port's, cleaned up transfers Port matched every manifold coupler, intake and exhaust...
    Dual outlet Fuel pump
    Dual cooling seperate circuits for pipe and motor
    Weisco pistons (750 cc's)
    caged wrist pin bearings
    Hot Rods Crank trued balanced and welded
    Dual battery mod w/ selector
    K&N flame arrestor w/ outerwears
    Hull/Pump:
    Umi steering
    Custom Paint
    R&D venturi/nozzle
    Custom Auto-drop
    Skat Trak Swirl impeller/Solas
    Top loader intake grate/and a scoop grate
    Hydro-turf seat cover and mats
    Tiny-tach
    Dual cooling outlet on pump
    3 500gph bilges
    Runs on 110 leaded racing fuel and 50:1 amsoil dominator...winterized after every ride...Did the porting myslef via Sport Port by race logic...
    PWCToday Guru exile's Avatar
    Mar 2006
    South Africa
    How fast are your hxs waterworx&swiftman????? Im currently doing a waveblaster1&superjet project...I want to build hx complete mod race ski asap....hxs are the ultimate race ski....
    Va Va Voom!!
    PWCToday.com Is My Home Away From Home DZRacing1's Avatar
    Jan 2006
    Indianapolis,IN
    my hx is 59-60 mph and gets there in a hurry.
    Sep 2005
    Wa state
    Quote Originally Posted by DZRacing1
    what all do you have done to it?
    Yeah what he said.
    Mar 2006
    South Africa
    I heard of a hx 71mph in texas???? so what speed r the top 5 racers going at havasu???? the nz and thailand blokes....
    thanx in advance!!!
    Va Va Voom!!
  9. #29
    Sep 2005
    Wa state
    Quote Originally Posted by exile
    thanx in advance!!!
    It wasnt under 800cc's then....Is that even possible sounds fing crazy
  10. #30
    Resident Guru Sanford's Avatar
    Dec 2005
    Freeride capital of the world
    swiftman, I'm not picking on you but that wiring in your ski looks scary.
    Keep the HX pix comin'....
