    May 2006
    nj
    R&D Hydraulic Trim System for SeaDoo VTS Models
    Do any one know any thing about R&D Hydraulic Trim System for SeaDoo. how in work and will the VTS guage still work
    PWCToday.com Is My Home Away From Home dsolie's Avatar
    Dec 2004
    Olympia, WA
    Re: R&D Hydraulic Trim System for SeaDoo VTS Models
    What specifically do you want to know? Mainly used for a race setup, not much use for a rec rider.
    They will keep your bow in the water while turning. In most XP's it replaces the VTS box, so your VTS and Gauge will no longer operate.
    Dan Solie
    PWCToday Investigator - Public Ouster - Scamdar Operator
    04RXP (the "Instigator")
    94xp (freestyle mods)
    95xp (faster than the 94)
    JS550 (the toothpick
    "Honesty is always the best policy."
    www.WaGuns.org
    May 2006
    nj
    Well my VTS down not work and the guage is broken so i was looking for a easy cheap way out. I plan on make my xp into a racer
    PWCToday Guru 427racing's Avatar
    Feb 2005
    lincoln ne
    R&D are junk. Been there, done that. Get a Baker set up. The R & D systems do not work well. They stick, or at least mine did. The Baker system has springs and help with the recoil of the hydraulic cylinder. My opinion.
    Fix it until its broke
    PWCToday.com Is My Home Away From Home Rudedog's Avatar
    Nov 2003
    At home. Why, where are you ???
    Baker systems rock, work real well with a auto drop from an
    RXP also.....
    good luck
    rudedog
    The faster you go, the faster you wanna go. RPM
    Bomber Eyewear, Impros, KMG
    Jul 2009
    Toronto, Ontario
    Anybody know where I can find a baker trim setup for a 96 XP?
    Jun 2010
    Alberta
    How much movement do the baker or R&D quick trims move the nozzle at the rear? the ones i've seen only seem to move the nozzle an inch down. Where as the VTS system moves it around 3 inchs.
