Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 56
  1. #31
    May 2010
    Hempstead Tx
    Re: seadoo info gauge repair
    Quote Originally Posted by nemiro View Post
    I did this last night on my 96 GSX, it worked perfectly! I thought the gauge was shot. Even after I removed the old film, it appeared that the display was not coming to life, but placing the polarizer on it made it clear as day. Thanks for this great article!
    Where did u get the film I emailed the guy who made the write up but nvr heard heard back he said he sells it but no reply
  2. #32
    PWCToday Newbie Madfish's Avatar
    Jul 2009
    Clearwater Beach, Fla
    I have a question: If your gauge works, but the polarization film is f---cked, will you be able to see anything at all displayed on the gauge?
    Anyone?
    My gauge shows nothing, so before buying another one I took it apart and cleaned off the old polarization film, cleaned glass with denatured alchohol, then re-installed the gauge, and there is still Nothing displayed on the gauge. Nothing.
  3. #33
    If you didn't put new polarization film on it you will never see anything, without the film the LCD does not work.
  4. #34
    Aug 2010
    Central, Illinois
    Does anyone have a picture of a bad gauge and a fixed one?
    I recently bought a '96 GSX that the gauge was water logged and complete shot, I installed a new gauge which works, but out on the water it can be a little hard to see, I'm fairly sure it's just because of the sun glaring on it, but if anyone has before and after pictures that would help.
    My screen is wrinkled or anything.
    Thanks,
    -TheChad
    1996 SeaDoo GSX (787)
    - Bill O' Neal Jet Kit
    - ProK Flame Arrestor's w/Outerwares Pre-Filters
    - Worx Racing Intake Grate (WR 208)
    - Hydro-Turf Traction Pad's (Cut Diamond Pattern)
  5. #35
    Jul 2009
    Can anyone else confirm what WFO is saying?
    Without the polarization film, there is absolutely nothing? No light emitted or anything at all visible? Even in the dark?
    So the only way to know if my info guage works at all, is to take it all apart, order and install polarization film, then re-install it and hope it works?
    It just sounds too simple that the polarization film solves everything.
  6. #36
    Normally I would take offense to this but I remember asking the same questions when I read the ad on Ebay, thats when I started doing my research and ran across this article, it should answer any questions you may have regarding LCD's.
    http://electronics.howstuffworks.com/lcd.htm
  7. #37
    Jul 2009
    I have a tip for those who - like me - think/hope that the only thing you need to fix your Seadoo LCD info gauge is to buy $10 worth of polarization film and your gauge will work just like new again. NOT.
    Turned out to be a total waste of time removing all my gauges and all those wires, taking the info gauge all apart, buying some polarization film, waiting for delivery, putting it all back together, only to start my ski and find out what I believed all along, that my gauge is actually F--KED and there is no fairy tale ending.
  8. #38
    Jul 2010
    MS
    all you have to make sure is you buy "polarized" tint or else it will not work. You should be able to pick some up at auto zone or somewhere like that or the super cheap route would be to take the gauge apart carefully scrape off old film and use some polarized sunglasses works great just cant read gauge with no glasses on
  9. #39
    Jun 2009
    Deltona FL
    Well, it fixed mine. But you could tell it worked before I replaced the film. There was a very slight indication that some information was underneath the wrinkled and brown film.
    That is just my particular case.
  10. #40
    Jun 2007
    Fort Lauderdale, FL
    Fixed mine too what a pita, but it works now. Madfish I didn't read the whole thread what year and model is your ski?
    2012 Seadoo GTR-4" Kana intake, Resonator delete, Vtech, XIC, ET127-other tweaks-77mph @8400 rpms.
    1997 Seadoo GTX-500+ hrs, Bill O's Rejet, F/As, Solas PPG Tuned Prop -54.8 Gps at 7040 rpms-Rebuilt engine, custom painted, 97 SPX waterbox, ride plate bolts filled in.
    1996 Seadoo GTX-120 hours-Rejetted/FAs,NuJet Prop (pitched by me)-better on bottom end and chop then the 97, 53.8 Gps at 6920 rpms.
    1996 Seadoo GTX-116hrs, FA/Rejetted/Prop/-NJ vacation ski
