    1997 GP760 Oil Question...
    just picked up a 97 GP760, 100.3hrs, 2 life jackets, cover, trailer all in awesome, awesome shape for 2400.
    Prior owner gave me a gallon of quicksilver pwc oil to go with it, which is what he always used. My only concern is that the sticker on the craft says use a tcw3 oil, and the QS PWC says its not fo machines requiring tcw3 oil. Is this going to be a problem??? Do I need to drain and change over to QS tcw3 2 stroke oil???
    James
    Jan 2004
    New Concord, Ohio
    Re: 1997 GP760 Oil Question...
    I would drain and change it. I have used the Penzoil TW3 from Walmart on all my 2 stroke skis that were not Seadoo. I have never had a problem with Penz, but others will say different. If the ski is modded then you may want to look for a little better oil, but if not then I think you would be fine.
    Photobucket - Video and Image Hosting
    PWCToday Regular CFW's Avatar
    May 2005
    Winter Haven, Florida
    i have the same GP 760,
    I run the Penzoil 2 stroke sythetic blend in the oil injection with no problems.
    If and when the motor goes I will eiliminate the injection and pre mix the same oil on this boat.
    AK
