Results 1 to 10 of 19
    harleymike
    Guest
    1998 SeaDoo gsx limited
    Does anybody have any input on this model? Thinking on buying one that has 104 hours on it. Would appreciate any input...Thanks, Mike
    PWCToday Regular dewsy's Avatar
    May 2003
    Oak Brook, IL 60523
    Re: 1998 SeaDoo gsx limited
    they're pretty nice from what i've heard... i wouldn't mind having one for the big rollers on lake michigan...
    -dewsy
    X racer...
    Guest
    very good jumper, very bad in the chop, motor is a reliability catastrophy.
    plus it has purple trim (sorry I just threw up in my mouth a little bit)...
    harleymike
    Guest
    Quote Originally Posted by 11
    Thanks for your input! I know it has purple trim...yikes but the price was ok for that year and its well taken care of. $2200.00 I thought was a good price....Mike
    harleymike
    Guest
    Thanks for your input....Mike
    Guest
    price is good but make sure the pipe gasket was updated, because if it wasn't it will leak and spray water right into the carbs.
    harleymike
    Guest
    Quote Originally Posted by dewsy
    -dewsy
    harleymike
    Guest
    Was this a recall or a modification I need to do and is it a new style part?
    Thanks, Mike
    Top Dog KevinS's Avatar
    Feb 2004
    Pilot Mountain, NC
    To 11's reply, I would add that it IS actually a two-person craft as long as those people are between average and small. I have ridden a GSi(same hull) with more than 350 lbs on it without too much trouble. But it is still fun when you are alone. If I had to own just one boat, this would be it because it is pretty good at everything.
    The ride in only slightly smoother than an X4 in choppy condition. I used to hear people say that it will throw the rider without warning. Never understood this until I rode a slalom course with my bro and another rider ahead of me. One second I am doing good and wondering why they are so slow then next I am flying thru the air hoping the boat doesn't hit me.
    I have had mine for two seasons and, except for a big goof by me, I have only had a rotten battery cable to deal with. The goof? I added sponsons and apparently left an exhaust hose loose. It popped off and sunk the boat. I was able to get it running again but didn't notice that water had entered the oil tank(I still don't know how). Water is a very poor substitute for oil and a seizure followed.
    The only purple left on mine is on the sticker that surrounds the fuel selecor and the little plastice peice under the rear loop(where the pissers are).
    PWCToday Regular gofastguy's Avatar
    Jan 2006
    canton, ohio
    I bought mine last season with only 70 hrs. and have been having a ball with it. It outruns almost anyone on the lake with minor mods. Downside is the ride quality. If you ride 2-up, your passenger is basically holding on for dear life at high speed. Most people seem to say you need to cross your fingers to get more than 100 hours out of the 951 engine, but I have had no problems...
