Best Impeller for a Yamaha superjet
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
    May 2003
    South East Michigan
    i have an 03 superjet with a few mods that are Head/b pipe/ msd enhancer i was just wondering what would be the perfect impeller pitch to get for this set up and what brand solas,skat trak,etc its for freestyle not racing thanks in advance
    2000 Sea Doo XP 1050
    2003 Yamaha Superjet
    2007 MV AGUSTA F41000R
    2006 Yamaha R6 track bike
    PWCToday Guru Speedfreak's Avatar
    Nov 2001
    Southern ILL.
    Re: Best Impeller for a Yamaha superjet
    Just go all out and get a solas concord cut back freestyle prop you will be happier that way and you won't have to change out your prop in a few years for a lower pitch.
    I shoped for used (didn't want ot spend all that money) and got a solas "S" prop. I had a pipe, head with 200+ pounds of compression and MSD. A buddy with the same year ski only had a pipe. His ski had more low end than mine and it was all the concord. So just get one of thoes arm rippers right off the bat.
    WHEN WILL IT WARM UP??
    May 2002
    Melbourne Australia
    Ill second that, I have mods like you & run a Solas/Impros 13/15 3mm cutback. Its awesome..
    dirk_diggler
    Guest
    i have solas 13\16 concord i freeride and race it works well
    May 2003
    South East Michigan
    thanks guys anyone else a few people told me get a 15/19 pitch i think that will be too much isnt 14/18 or 14/19 better
    dude, listen to what they are telling you.
    13/17 is the stock lowest available concord, have impros repitch it it 13/16 ( or even 12/15) with the cutback.
    and it will RIP off of the bottom.
    I run a 12/15 cutback on my 650 superjet ( pipe/head/msd enhancer)
    its very strong right off of idle for a worn out 650!
    I no longer post on this site.
    MADMAT
    Guest
    I love my 13/16 but I did'nt know about a 12/15 when I bought mine from 24-7.
    Quote Originally Posted by MADMAT
    13/17 is the stock concord pitch ( the lowest one from solas)
    impros can make it whatever you want, I told him my engine setup, my weight, and my intent ( ripping bottom end)
    and he suggested a repitch to 12/15
    that may be too low when I stick my 701 in there, but I sort of doubt it.
    ive got a 13/16 too just in case though.
    Im pullnig 7200 rpm with the 12/15, on a 650 with 180 lbs in front cylinder and 150 in the back.
    its a great match in my opinon
    Nov 2001
    Southern ILL.
    I have the "S" prop and it is a 14-17 pitch I bored the nozzle to 85.5 mm then turned the stock cone down as far as I thought I could without going through to make more pump room for low end punch and I can out run a few sitdowns on my lake and every standup out there. Which is sad very sad since I was going for low end.
    I would get somethign like 12-15 and then wait to see what you thought before you bored the nozzle or a new cone. That speed is just waisted low end punch.
    Jun 2005
    ATLANTA
    i herd the nujet 14/17 was freestyle prop. i was thinking about trying one .any one tried nujet?
