Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    I dream skis LBE's Avatar
    Feb 2005
    Long Beach
    Yamaha 701 stator instalation question
    Putting a new stator in my 701. Question is, where do I thighten the plate? I don't want to alter the timing. Should the screws be in the center of the adjuster? Is there an easy way to set it to stock location? When I have taken the plate off in the past I marked the location so there was no issue, but this is a new plate. Any suggestions????
    Get out there and ride. No one ever looked back and said \"I should have spent more time in the office\".
    LBCrew
    www.sidestageprinting.com custom shirts, stickers, banners and more all fo cheap!
    PWCToday Guru 1raptor's Avatar
    May 2004
    NEVADA
    Re: Yamaha 701 stator instalation question
    Quote Originally Posted by LBE
    I thought there was a mark on the case and on the stator you just line them up I know for sure there is on my kawi's but I cant remember for sure on my 701's I have a spare motor in the shed if no one else pipes in I will check this weekend.
    1994 X-2 (750)
    1994 Blaster 1
    1999 GP-1200
    2000 GP-1200-R
    May 2004
    Blowing up Motors
    There are marks on the cases and on the stator. Line them up...center mark is 0 degrees, and the further mark is advancement.
    PWCToday Guru Phill's Avatar
    Nov 2005
    sinkin' skis
    Should be some little arrows on the stator and the case just line them up
    Feb 2005
    Long Beach
    AWSOME!!!!!!!!!!!
    Thanks guys, I didn't even see those marks.
    Matt: I only have one mark. Would it be worth it to advance it just a little? Turning the plate counterclock wise would advance it, correct?
    Thanks again fellas.
    LBCrew
    Nov 2001
    "Brian, todays the day"
    On my surf boat I run Enhancer, +4 degrees advance, w/ 175#,"B", mild porting. Pump gas. No prob. Just no drag racing allowed. Makes your ski very responsive. Snappy. I would bump it up if thats all you do with this ski. To advance move the stator opposite the diredtion of engine rotation. 1mm = 1 degree.
    Via Con Dios Racing
    Pat Tillman Inc.
    Todd Beamer & Co
    'cause Freeriding ain't Free
    PWCToday Guru TXJfrosty's Avatar
    Angola, NY
    Quote Originally Posted by StandupEd
    That's awesome to know... one question, which direction does the engine rotate? I would like to try that out. Thanks bro...
    Frosty
    If you want the ultimate, you gotta be willing to pay the ultimate price.
    May 2004
    Blowing up Motors
    AWSOME!!!!!!!!!!!
    There should be one mark on the cases, and three (right next to each other) on the stator. One center mark, and one retard and one advance mark. The advance mark is further away from the center, in the CW direction. If you don't have those marks, rotate the stator CCW about 3-4mm.
    Nov 2001
    Quote Originally Posted by TXJfrosty
    one question, which direction does the engine rotate? .
    I always forget, If you take a gander at your prop it will solve the mystery. Better yet hang an old one on the shop wall.
    Via Con Dios Racing
    Pat Tillman Inc.
    Todd Beamer & Co
    May 2004
    Blowing up Motors
    If you stand in the tray, it rotates the ski cw, so the engine spins CCW, looking at it from the rear coupler.
