Blaster Mod Pipe in Square nose - Page 2
Results 11 to 20 of 26
    Jan 2005
    Havasu / Canada
    Well I dropped the engine and pipe into the hull last night to see where I was at, it fits in there nice and snug. I'm going to yank it back out and grind some of the side wall down for a little clearance on the side and at the front I'm either going to try heating the tank and forming it or dent the pipe. Probably try forming the tank, sounds like a fun experiment.
    Thanks for all the ideas.
    Joe
    Top Dog T-Bone's Avatar
    May 2002
    Margaritaville
    heating the tank empty is fine, just get rid of the residue and keep it un capped.
    SUR#82
    pwctoday....its like working with my brothers kids.
    PWCToday Regular keefer's Avatar
    Jun 2003
    Tennessee
    Re: Blaster Mod Pipe in Square nose
    I am trying to do the same thing on a square nose and wondered if this chamber could be hard mounted with custom brackets that I could have made from SS. I was not sure if hard mounting was even an option or is using lord mounts absolutely necessary
    If you can't fix it finish breaking it !!
    Frequent Poster rmbcracing's Avatar
    Jul 2002
    Lake Pueblo, CO
    Keith, go with the lord mounts.... They exist for a reason. I tried the Blaster mod pipe on my SJ this summer. I did not have the upper lord mount bracket so I hard mounted it there and it just shook the bolts off in one ride. I did have the lord mount on the flywheel cover bracket and it held the pipe pretty well by itself. That's how the TNT chambers are run, with just the front lord mount.
    Jun 2003
    Tennessee
    Quote Originally Posted by rmbcracing
    Thanks Neil, the reason I asked is because when we were in Daytona in Nov. Paul from Magoos was going through lord mounts like crazy on his TNT chamber. I guess I might try making a special bracket for the top mount that will fit a lord mount and run a bottom lord mount also. Are you gonna make it to the MotoSurf???
    Resident Guru brentR's Avatar
    Jul 2004
    Toronto, Canada
    Im gonna be attempting this blaster mod pipe in my squarenose pretty soon, anyone have any decent pics?
    94 modded B1
    90 stock SJ
    May 2004
    Blowing up Motors
    Here's one in a round. Should be identical.
    Jul 2004
    Toronto, Canada
    thanks Matt... anyone know how much i would have to grind? and what tool would be most appropriate for it.
    94 modded B1
    90 stock SJ
    May 2004
    Blowing up Motors
    I used an angle grinder and just took off the ribs in that area. Of course, if you've reinforced, you've already done that.
    PWCToday.com Is My Home Away From Home Prem1x's Avatar
    Apr 2002
    Austin, TX
    Someone should start replicating/re-manufacturing those TNT chambers.
    Taste-testing premix quality since 2006
    FS: Parting out RN SS Superjet & misc Kawi/Pol
