Blaster Mod Pipe in Square nose
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Jan 2005
    Havasu / Canada
    Has anyone tried to cram a blaster mod pipe into a square nose?
    Will it fit?
    thanks for your help.
    May 2004
    Blowing up Motors
    It will fit. You may need to reshape the gastank a bit with a heat gun (empty, of course), and perhaps dent the chamber a bit. But it fits.
    Jan 2005
    Havasu / Canada
    Cool, thanks!
    Top Dog T-Bone's Avatar
    May 2002
    Margaritaville
    Do you use the same header (blaster) pipe combo?
    SUR#82
    pwctoday....its like working with my brothers kids.
    May 2004
    Blowing up Motors
    Yes. Just the chamber is different.
    Art_Maybee
    Guest
    Heat on an empty gas tank is a LOT worse than heat on a FULL tank.
    If you are going to heat the tank to shape it, you might want to try filling it with water first. Don't apply heat to an empty tank.
    May 2004
    Blowing up Motors
    Quote Originally Posted by Art_Maybee
    Empty and dried out for a couple of days (in my case), I should add. :razz:
    PWCToday Guru blaster94's Avatar
    Aug 2003
    NC
    If you fill the tank with water all your gonna do is heat the water up. Use a heat gun on an empty tank and take it easy not to over heat the plastic.
    94 Blaster x2 94 SJ 04 R12X
    Click this=>https://www.awahq.org/p/joinNow.php And Join!
    I didnt have to heat the tank to clear,just a small dent in pipe will do & maybe covered with a piece of hydroturf.
    You will need to put a BIG dent on the side of the chamber to clear the side wall or grind the wall.
    PWCToday.com Is My Home Away From Home bad93blaster's Avatar
    Jan 2005
    billerica mass
    i would run the exhaust off my truck through the tank before id heat the tank
    there is no fun playing stock
