plans for a pwc lift
are there plans available for a PWC lift. Has anyone built was and how good are they?
-Jim
Try searching the forum. You will find some. If you want to go the easier route, buy a davit. They're only about $400.
Re: plans for a pwc lift
Did you have any luck finding plans for PWC lift? I am in the same boat, so to speak. I am looking to build a DYI PWC lift. Please let me know what you find out?
Thanks,
Knick
this is what i use at my cottage, both a big lifting dock and a bunch of hand crank lifts. They work great and are very simple.
make a long rectangular frame, bolt the front to the dock ( the pivot point) ad bunks on top of it, and a lift tank at the rear.
sink it, and its a ramp, drive up, lift the tank, the entire thing is high and dry.
it needs limiting chains to not drop too far, and some calculations or trial and error to figure where to put the lift tank, and some lateral stabilization and a way to lock it up and out of the water ( in case of a tank rupture or hose leak)
I no longer post on this site.
Fixin' To Get Slapped
Retired...
Hey Mouthfulloflake, i like your idea. can you be more specific or better yet send me a photo? thanks, knick
Here's some pics I took of a sample...
this is pretty close to what I was talking about.
I would build it wider, and have 2 sets of bunks.
so that it will hold 2 skis side by side.
No photos, I havent built it.
I can show you an empty dock, and a pile of steel, and maybe a photo of a welder that is collecting dust.
Hello ..do you have the pics for a homemade PWC lift ..appreciate seeing how these are built. Marc
- You may not post replies
- You may not edit your posts
Forum Rules
