61X case porting... whats the basics?
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
    Resident Guru romack991's Avatar
    Apr 2004
    NE Indiana
    I've searched for some case porting threads but didnt really find any. I've got the sport port templates so I'll be doing my cylinders. Thought I'd try to do some with the cases if I can figure out the key points. Where to remove and why? whats the point of filling in the cases with epoxy? or is that just for 62t cases? any info or pics of port jobs would be appreciated.
    and i love theory and technical crap, so spare no explanations.
    thanks in advance.
    PWCToday.com Is My Home Away From Home mile9c1's Avatar
    Oct 2002
    Grand Rapids, MI
    You can't port the 62T cases very much unless you fill in the voids on the intake side with epoxy, because you'll cut into the voids and that won't work for obvious reasons.
    A lot of people also fill in the "fingers" in the 62T cases but the 61X cases don't have fingers.
    I'm not sure what I'd do to a set of 61X cases... I haven't looked at a set in a while.
    Oct 2002
    Grand Rapids, MI
    Okay I just looked at a set of 61X cases... pretty sad. I would shave some material off the top of the intake ports near the crank side, on the left and right sides only (not the middle). If you take material out of the middle on top you will make that boost (sp?) port shorter (shorter like the 62T's have it). As Jr.Magoo said on the Sport Port thread, a longer boost port is better for low end.
    This'll help the intake charge flow up into the transfer ports.
    Apr 2004
    NE Indiana
    So like wildman did on this post.. are his 61x or 62t, i have no clue what the intakes look like on either of em. mines still together at the moment.
    http://www.pwctoday.com/viewtopic.php?t=71262
    Oct 2002
    Grand Rapids, MI
    Wildman's are 62T cases, they look a lot different than 61X cases. But I guess porting would be similar. I think they call that "tunnel porting".
    I would try to take more off the top and less of the sides, but that's just my hunch. You'll see when you look at your cases. The 61X reeds feed more into the side side of the crank whereas the 62T reeds feed more into the top side of the crank.
    I dream skis Roo's Avatar
    Jul 2004
    Lake Orion, Michigan
    maybe Slymo has pics of his cases that Keith over at Head Enterprises did...
    he supposidly is the man when it comes to 61x motors.
    i would like to know as well, as i have a 61x motor in my machine that id like to dismantal and work this winter if i get bored.
    -Roo
    May 2004
    Blowing up Motors
    Well, if Keith Head is the man, ask Uncle.
    Jul 2004
    Quote Originally Posted by Matt_E
    lol, im going off of the huge write-up Slymo did...
    Jan 2004
    In a van, down by the river
    Keith knows his 61x stuff, but im guessing no one will post pics.
    Yadda Yadda
    May 2004
    Blowing up Motors
    Anyone have pics? I'd like to know.
