Results 1 to 9 of 9
    Aug 2004
    Florida
    Removal of Water in Gas Tank
    I had my jet ski covered, and gas cap loose (so condensation does not form, etc).
    Hurricane Wilma blew the cover off, and gas cap off also.
    So. water rained into gas tank.
    I have not or will I turn on the jet ski.
    This jet ski will not be ridden again for 5 months (I had winterized it previously with fuel stabilizer, etc).
    What do I do?
    Siphon out all the gas, add some water removal chemical, or will the water evaporate itself out?
    Top Dog Mark44's Avatar
    Jan 2003
    Arnold MO.
    Pull tank out and clean, let dry then reinstall.
    Mark44
    Oct 2003
    Siphon the water out through the reserve line. I've done this and it works. Gas and water don't mix and water is heavier, thus it will be at the bottom of the tank. A few drops of water may remain, but that won't hurt anything.
    Water:'03Octane,'94B1,'95B1,Land:'06 Busa,'99GSXR750,'91Vmax,'91 5.0 GT, '86 SVO. Yes, I know..... I have a problem.
    Feb 2005
    Upper Bucks, PA
    Blow in the the tank vent to start the siphon rather then sucking gas
    08' sj
    Top Dog gj_fx1's Avatar
    Sep 2002
    dayton
    I think if you only only pump via the reserve line you
    may have a good bit of water remaining. Do that first but then see what you can do to get all the way to the bottom of the tank. (Pull the hose port cap, or whatever)
    Details depend on what model etc.
    Feb 2005
    Upper Bucks, PA
    Once you empty all you can get out through the reserve pull the tank. You will see little beads of water rolling around on the bottom of the tank under the fuel.
    08' sj
    Jul 2004
    ny nj
    what about putting ski on floor and just flipping it over with the gas cap open..
    Aug 2004
    Florida
    It is a Kawi 12F, by the way.
    Feb 2005
    Upper Bucks, PA
    Either pull the tank and dump it out completly or get a shop vac and suck out all the gas the reserve didn't pick up. I've sucked up gas with a shopvac with no problems and so did mythbusters but I would still be carefull. Ethennol/Denatured alcohol should mix with water so you could flush the tank with that to get out any droplets of water. If you don't completly empty the tank the water will still be in the bottom and the little beads will get sucked up no and then.
    08' sj
