Results 1 to 8 of 8
    Apr 2004
    Nebraska
    refilling battery cell.....use water or acid?
    I took the batteries (Everstart brand) out for winterization and noticed that each battery has one cell that is low on acid. If I use the leftover acid from when the battery was initially filled this summer will it hurt the battery? I was always taught to use distilled water when filling battery cells but since I still have some acid could this be used instead?
    Just curious. Besides, this would be a good place to dispose of the leftover acid.
    You can fix anything with a big enough hammer and plenty of money.
    Moderator
    CaptnKirk's Avatar
    Feb 2003
    Northern Michigan
    Im going to assume that its sulphuric acid that youre refering to. Ive always used distilled water myself, but from what Ive read, I dont think that using acid will hurt the battery. Keep it on a battery tender after you fill it and it should be fine.
    Captn---
    Skipper: Kowalski, analysis.
    Kowalski: I'm picking up good vibrations.
    **The information obtained in my hurricane thread is courtesy of NOAA, National Hurricane Center and National Weather Service.**
    Liquid Militia*****K38 Water Safety*****
    PWCToday.com Is My Home Away From Home BigKahuna's Avatar
    Nov 2001
    Tuscaloosa, AL
    do not add acid, distilled water.
    Apr 2004
    Nebraska
    Quote Originally Posted by CaptnKirk
    Im going to assume that its sulphuric acid that youre refering to. Captn---
    It's the acid supplied by the manufacturer when the batteries were purchased. I'm pretty sure that it's sulphuric acid.
    Apr 2004
    Nebraska
    Quote Originally Posted by BigKahuna
    OK, thanks.......but would you explain why not use the acid?
    Not trying to be a pain, just curious.
    resident guru JetEd73's Avatar
    Dec 2001
    Cleveland, TN
    the acid you use when brand new contains water, you added watered down acid to being with and the reason that one cell is low is because the water boiled or evaporated out, they don't lose acid just the water sooooo....you just top them up with water.
    http://www.drna.org
    I'll keep my guns and my money..
    You can keep your "Change"
    99 Yamaha XL1200 Limited
    Riva Stage 2
    Apr 2004
    Nebraska
    Quote Originally Posted by JetEd73
    Thanks.......I suspected something like this but chemistry was a loooonng time ago and thought I'd better ask someone elses advice. I gather from what you tell me that adding additional acid would be "too much" acid and probably have ill effects on the life or performance of the battery.
    I assume that adding distilled water simply adds enough hydrogen and oxygen to return normal function to the cell.
    KDog
    Guest
    You should be able to buy already mixed sulphuric acid from an auto shop. Usually the mix is around 10% - 15% acid to pure water.
    You can add this or distilled water, NEVER add tap water.
