ZXI 900/1100 compatability
Anyone know if a CDI from a 96 900 ZXI will work for a 96 1100 ZXI? I thought they were pretty much the same engine, just bigger bores for the 1100.
resident guru
i assume you are talking about the igniter, (black box),
they do have different pn's 900zxi (21119-3744) 1100zxi(21119-3745)
but i would bet it would work on each other.
the 3 ignition coils are all the same.
1988 JS550A7 modified, overhauled many times.., still riding @ my age, a little slower
sbn44 w/OP stack, jetsport head (170psi), factory halfpipe w/ flow control valve,Impros 14.5 S/T impeller, bored nozzle. OEM crankshaft.
T/R scoop grate, jetsport rideplate. seadoo 580 starter. advanced timing
1997 750zxi (stock) boyesen power reeds>>sold
1997 900stx (stock)>>sold
1987 650sx >> sold
1984 440 converted to R & R Jet tech stage 2 550 >>sold
You must be looking at the ebay auction as well.
I would call a dealer and double check.
I am ordering one today from ronayers.com
thanks to spreedreed8's link and info.
It seems as though this (the igniter) is a common problem and I guess I don't want to risk getting another bad one.
If you don't like it, leave!
"That's life, what can I tell you."
Yep. I was looking at the auction. Where did you find the ZXI 1100 at ronayers.com? All I could find were motorcycle engine parts.
I had to look up the part # here:
http://buykawasaki.com/Default.asp?s...ctVehicle.asp?
ronayers.com does not have jet ski P/N's on thier system but they can get any Kawasaki OEM part you need. If you look up the P/N and plug it in thier search field it should show you the price.
I then called Ron Ayer's and they are getting it UPS next day air for me
and I should have it Thursday.
They where very helpful and great to deal with so far.
I will post when I get it.
Thanks for the link and for mentioning ronayers. The prices are better than bike bandit, where I bought a bunch of other stuff.
The part came in today as the folks at ronayers.com said it would.
I highly recommend these folks for OEM Kawi parts. I have never dealt with them before and they went out of thier way to help me get my inginter in time for the weekend ->
Thanks agian to speedreed8 for the heads up on these guys.
I recommend them also. I ordered some motorcycle parts from them (fork seals). My order got jacked up - I was told that fork oil was on back order, but it turned out that the fork seals were on back order.
Called after receiving my order - they overnighted the parts I needed for free. (I paid for the parts, of course)
- You may not post replies
- You may not edit your posts
Forum Rules
