94 Polaris SLT 750 - MYSTERY CHECK VALVE [Screw / bolt]
    May 2017
    UT
    Help, please! - Can you help identify this mystery check valve / bolt?
    It was lying in the bottom of my client’s boat - I’ve searched manuals but I cannot find what it is, or where it belongs, or what it does… ??
    It appears to be imperial [vs metric] - about 3/8" long, head appears to be 5/16 hex, 3/8" long under the head, and the thread appears to be 1/4-28 ... ??
    Re: 94 Polaris SLT 750 - MYSTERY CHECK VALVE [Screw / bolt]
    It's a broken off grease zerk from the PTO.
    Riverside, CA
    6
    There is an automotive grease gun needle used to pump
    the grease.
    Bill M.
    Aaaahh, not broken then, maybe just dropped and unfound at the factory. Just grab another one and move on!!!
    May 2017
    UT
    Yea! Tks much to both of you for the *appreciated* assistance! /awd
