Help: installing an oversized tank w/surf brace
Results 1 to 9 of 9
    PWCToday Regular SirGodSpeed's Avatar
    Nov 2014
    Lake Havasu City
    Has anyone been able to do a oversized tank with a surf brace? Getting held up where the fuel pickups are protruding into the path of the surf brace. Any help or insights would be greatly appreciated! Thanks in advance!
    88' 650 X2
    93’ 750sx Mod Stock
    98’ 750sxi Pro Limited
    Re: Help: installing an oversized tank w/surf brace
    You need the other style stainless steel pickups where they make a 90 degree bend exiting the tank, like the ones in this pic
    Nov 2014
    Lake Havasu City
    I do have the west coast pickups with the 90° bend and they actually protrude even further into the surf brace. Will get some pictures of the stainless pickups when I get home.
    88' 650 X2
    93’ 750sx Mod Stock
    You may have to have some custom made with very little stickout and a really sharp bend or you could possibly use a WAX racing or other style pickup depending on how much room you actually have. There is also the not so nice option of putting a cap on that and drilling the tank for push in pickups like these.
    I have a few options for you below.
    https://www.blowsion.com/blowsion-fu...iller-kawasaki
    https://www.blackmarkitinnovations.c...et-fuel-pickup
    https://fly-n-ty.com/products/440-55...d-oem-location
    Nov 2014
    Lake Havasu City
    Thanks for your feedback. I have little under .600” of room to work with. I ended up modifying the stock pickups and added street elbows with barbs to make it clear. Will be adding some black RTV around the threads to ensure it’s sealed.
    4F5C2C31-9E7A-4F79-89C0-8CCA26E69148.jpeg76CE3419-ABFC-46C2-8458-BF424004D05B.jpegA970622C-C155-4979-8752-9E1DB116FF0A.jpeg
    88' 650 X2
    93’ 750sx Mod Stock
    Black RTV and gas are not going to work, you willl need some other type of sealer there. tere is a sealer called SEALS ALL that is gas resistant
    https://eclecticproducts.com/product/seal-all/
    Resident Guru blasterdude's Avatar
    May 2007
    The Region, Indiana
    Nov 2014
    Lake Havasu City
    I did see that but was unsure of how much the pickups stick up past the cap as I have very little worm to work with but was able to figure something out by modifying the stock pickups to then tap street elbows in followed by some barbs to get the clearance I was looking for. Thank you though
    88' 650 X2
    93’ 750sx Mod Stock
    Dec 2014
    SRQ FL
    tapped properly some 5200 will work fine. Done it on countless SJ tanks.
