95 Sea Doo XP Won't Crank with Drive Shaft and Jet Pump Installed
    Aug 2022
    Ohio
    As the title implies the engine will start up no problem when the drive shaft and jet pump are removed. Once they are installed the engine won't turn over. I took the battery out and it was able to start my 97 GTX and 93 Kawasaki 750SS with no issues.
    I am able to hand turn the impeller with my hand so that can be ruled out. Could the starter be the issue?
    Re: 95 Sea Doo XP Won't Crank with Drive Shaft and Jet Pump Installed
    You sure the pump housing is not binding the impeller up when you tighten it down ?
    Loosen off al the pump bolts and see what it does, if it rotates them you can usually fire it up and slowly tighten the pump bolts back up a little at a time and the impeller will cut into wear ring and seat itself where it needs to.
    Aug 2022
    Ohio
    That worked! thanks for your help!
    Anytime man, anytime.
