XL800 slight miss during acceleration?
    Aug 2017
    Winnipeg Canada
    I have a 2000 XL800. New to me so no history on the ski. I cleaned the power valves installed the clips before I ever ran it. New plugs as well. Starts and idles perfectly. Good midrange and top end as well to 7000 rpm. But it does miss a couple of times on acceleration. I hear it more through the exhaust note when someone else is riding and I am on dock as it takes off.
    I do have some impeller ventilation that I plan on remedying with the pump seal kit. I don't imagine that is related but maybe someone knows better. I have not tried adjusting the slow speed pilot screws but again not sure if that would help. Any advice is appreciated. Thanks
    Riverside, CA
    6
    Re: XL800 slight miss during acceleration?
    Diagnosing a small miss can be difficult. It could be something
    as simple as the pilot circuit is a little too rich, a characteristic
    of the carb, or the changing water level inside the water box.
    Bill M.
    ...... or the changing water level inside the water box.
    Bill M.
    Very normal 'burbling' noise from the larger displacement 2 stroke watercraft. The Yamaha 800 and 1200 powervalve engines and the Seadoo 951 are the most noticeable. I believe it to be a combination of the exhaust pulses and specific exhaust pressure trying to blow through the water in the waterbox.
    Aug 2017
    Winnipeg Canada
    Thanks guys. I will try leaning the low side adjuster as it does seem like it loads up a bit on take off on first ride in morning. But maybe it is just the waterbox and not a problem. Would not have guessed that. Appreciate the responses.
