1996 Kawasaki 900 ZXI key switch replacement/alternative
Results 1 to 10 of 14
    Feb 2020
    Yuma
    The key switch on my ski is bad, 100%. New OEM key with switch is to expensive so I am looking for a direct alternative. Does anyone one have any idea how to use an alternative (key and switch) as a replacement for the OEM parts? I have looked thru just about all the posts on multiple sites with no luck. I know a lot of guys will be following this post so I hope someone can help us out.
    I donít really need a keyed switch if that helps me get this issue solved. I would also need a sketch to get it wired up if possible.
    Thanks in advance. You guys are great here and your posts really help me get this old girl running.
    Steve
    PWCToday Regular guy48065's Avatar
    Feb 2020
    Michigan
    Re: 1996 Kawasaki 900 ZXI key switch replacement/alternative
    The key switch wiring is basic. There's just one pair of power wires for 'On' and one pair that grounds the ignitor when 'Off'.
    96 & 97 1100Zxi
    Feb 2020
    Yuma
    guy48065 A Huge Thank You
    I really appreciate your help here. I think I understand the switch wiring and maybe I am overthinking it. Would I be correct in thinking I would need a switch that in the off position I would have continuity between W and BK/W ?
    That’s my problem locating a switch as most switches in the “on” position make the R and R/W and in the “off” position breaks continuity between R and R/W. Example an on/off toggle switch. With that said I am not sure how to control W and the BK/W in the off position with a single toggle or key switch?
    Are you thinking perhaps two waterproof toggle switches? Thats what I’m thinking looking at the wiring diagram?
    Thank you again, really appreciated!
    Feb 2020
    Michigan
    A DPDT switch means "double pole, double throw". Typically there would be 2 sets of 3 terminals on such a switch, each side isolated from the other, each having contacts that are closed in one toggle position and open in the other.
    It might be more of a challenge finding a proper waterproof toggle than I first thought. Those rubber boots that cover the handle only seal from the front. On a pwc that's designed to survive being submerged you should use a completely waterproof switch. Mil-spec, if possible.
    I thought these would be common on eBay or Amazon but I couldn't find any on a quick search.
    You might have to order from a REAL electronics supplier like Mouser.
    96 & 97 1100Zxi
    Feb 2020
    Yuma
    Thanks for pointing me in the right direction. I looked through the Mouser catalog and found the type of switch you described. I will have to call them to help spec the correct configuration as the catalog is complicated for my level of experience.
    Looks like this should not be difficult if I get the switch configuration correct. It’s a great inexpensive fix for a problem many of the guys have or will have.
    Can’t tell you how much I appreciate your help. I’ll be sure to play it forward and help someone when I can!
    Feb 2020
    Michigan
    You might like Digikey better.
    Easier to search, easier to order.
    Selection of IP68 waterproof DPDT toggles:
    https://www.digikey.com/en/products/...cA7tzTIAFoxCQA
    https://www.digikey.com/en/products/.../S6AWB/9698995
    https://www.digikey.com/en/products/...201SSQ/9829425
    https://www.digikey.com/en/products/...B-4B13/3190611
    That last one is "only" $18.75. I guess that's actually cheap for what it is. It probably costs the DOD $9000 each. Lol
    96 & 97 1100Zxi
    Feb 2020
    Yuma
    Right now, I am wading through the Mouser catalog you guided me too looking for a "red non-illuminated 12v sealed rocker switch". I think a red rocker would look nice on the dash as opposed to a toggle, but I may have to settle for a black rocker if I can't find red. Catalog provided below if you dare?
    https://www.mouser.com/datasheet/2/6...eet-370201.pdf
    The big challenge lies here, which one??? If I could pin down the specific part number problem solved? Any chance you could explain what, (on) vs on, indicates. I am just not sure what the parentheses () indicate?
    Thank you
    I really truly appreciate your help and the guidance provided!!!!
    Again, Big Huge Thanks
    Feb 2020
    Michigan
    (on) means a momentary position.
    For example the Trim rocker would be (On) - Off - (On)
    Digikey shows only one in-stock waterproof rocker that mounts in a round hole--but it's a big hole.
    https://www.digikey.com/en/products/...SXX2X/13239323
    96 & 97 1100Zxi
    Most boat kill switches make two connections like that, I believe they have two sets of contacts one set to disconnect ,. one set that connects two wires.
    Feb 2020
    Yuma
    Any thoughts on which switch? Be nice to find a non-illuminated toggle but having no luck.
    Thanks for helping
