HX Impeller tool
    PWCToday Regular rc-hx's Avatar
    Sep 2011
    SE Michigan
    HX Impeller tool
    I have a 95 HX with a stock impeller.
    I bought the ski new and know it’s stock.
    According to every site I look to buy an impeller tool from, the impeller tool is supposed to be the same as the tool used on many 2 stroke Kawasaki’s including the 1995 750 SS XI sit down.
    I have an old shaft from an 1995 SS XI that I use to remove impellers from a couple Kawasaki’s I have, however when I try to insert it into the HX impeller it doesn’t fit, too big.
    What gives?
    Anybody experience an issue?
    Rob.
    Re: HX Impeller tool
    The driveshafts ARE slightly different. The Kawi shaft splines are wider.....more squared off. The impeller tool has more V shaped, narrower splines.....like a Seadoo shaft. That's why the tool will fit both.
    Sep 2011
    SE Michigan
    Thank you so much.
