2002 Seadoo Sportster 951 Carbed - No Spark
Results 1 to 10 of 11
    May 2022
    Mansfield ohio
    I’ll try to summarize everything I’ve done as shortly as possible;
    - Replaced Pickup coil and stator.
    - Cleaned Pickup points on the rotor. They were corroded from water it looks like.
    - New battery this year.
    - New spark plugs, wires, coils, etc. (entire rear electric box).
    - Cleaned all grounds.
    - Ohmed out each wire to make sure no shorts from mag cover back to the box, grounds included.
    - Ohmed pick up coil (242 ohms).
    *Newest updates/findings;
    - I get 4.6volts at both white wires at the coils when both white wires disconnected and boots removed from the spark plugs.
    -If I connect the boots on the plugs and take a voltage reading at the white wires, it shows more like 3.8 volts.
    -If I leave boots off and hit start button with white wires off (won’t crank obviously) then voltage jumps to 11.9volts.
    -If I contact boots and white wires to the ignition coils then crank and measure white wire voltage, I show nothing.
    Does this sound like a short or something? I don’t understand how there is 3-4volts before I push to start.
    The previous owner put in an aftermarket Arieltek MPEM and I’m wondering if that isn’t part of the problem too. The rotor is a Denso rotor.
    May 2022
    Mansfield ohio
    Re: 2002 Seadoo Sportster 951 Carbed - No Spark
    Second question, is this trigger coil too far from the pick up points on the rotor to get a pulse? It seems like a rather large gap.
    Riverside, CA
    6
    About 1mm is normal. When the gap is that wide, the pick-up
    has problems or will not register the reluctor.
    Bill M.
    Did you test the old pick-up coil with an AC volt test?.
    May 2022
    Mansfield ohio
    Unfortunately I didn’t measure the AC voltage. The reason for replacing the stator/pickup assembly was mainly because of the stator being in rough condition. I cranked over and tested the AC volts of this new pickup and I get nothing.
    Is there a way to adjust the pick up coil or is it possible that the rotor is the incorrect rotor?
    May 2022
    Mansfield ohio
    Update:
    I bent the tabs on the pickup coil and now it reads on the tachometer when cranking. The one I bought off of eBay was bent the wrong way leaving too large of a gap.
    Now, I still have no spark. Over 5 times it would slightly fire the second I let off of the start button but when I am cranking it never even slightly fires. What could this mean? A short somewhere? In the switch itself?
    A few times while cranking it would stop cranking (before I let off of the button). A few times it would stop cranking and beep twice before I let off of the button too.
    But would any of this affect the spark?
    Thanks!
    Adam
    May 2022
    Mansfield ohio
    Anyone have any ideas?
    Riverside, CA
    6
    1-spark is new??
    I don't trust your new stator. It is new, not used?
    What previous testing pointed to the stator?
    Bill M.
    May 2022
    Mansfield ohio
    1-spark is new??
    Bill M.
    Hey Bill,
    the stator wouldn’t cause it to not start though correct? Yes it is new. The old one had corrosion so I replaced as a precaution when I was inside the magneto cover. It is still not firing up but it does now register 400ish rpm’s on the gauge when I crank it over. Still no spark. Wires resistance is good.
    Is there any wiring that can cause it not to fit from up near the start button? I notice the guy before me ran a wire from negative on battery with an inline fuse straight up to the controls under the drivers storage compartment.
    Riverside, CA
    6
    Quote Originally Posted by Airman89 View Post
    Hey Bill,
    But the large air gap would. Replacement stators with the wrong
    pick up coil seems to be a trend these days.
    It is a battery powered ignition, so long as the charging system is
    working properly, the pick-up coil, MPEM, ignition coil and stop
    switch are the ignition system.
    There maybe sensors or safety switches that are connected to
    the mpem too, but the large air gap is a real problem.
    I don't know. Maybe Myself or WFO has something to contribute?
    The only other thing I can suggest is testing the primary coil wires
    from the mpem with a peak voltage adapter for your multi-meter.
    If the peak voltage from the mpem is significantly less than ~150v dc
    something on the mpem side (pick-up coil, MPEM, stop switch, etc.) are
    the problem. If it is equal to or greater, something on the ignition coil
    side (maybe a ground wire) is the problem.
    I have a circuit, if you want to build one yourself.
    Bill M.
    It's been my experience that aftermarket electrics are a crapshoot at best. I'll take good used oem over aftermarket any day on most electrics. I would first get a known working oem stator and mag cup. If that doesn't work then I would yank the aftermarket MPEM and try that. It's VERY hard to troubleshoot these electrics when there's sketchy aftermarket parts involved.
