1996 Seadoo GTX Im at a loss
Results 1 to 10 of 17
    Sep 2021
    CT
    So I swapped out the MPEM, not knowing if this one even works. I checked the connections, checked the fuses and still nothing. I have power at the starter solenoid, I can jump the solenoid and the starter will engage. When I press the start/stop switch nothing. I don't have any power going back to the solenoid. No click, no beep, nothing on the gauges either. My head is spinning on where to begin.
    Re: 1996 Seadoo GTX Im at a loss
    Sounds like the little start relay in the front electrical box.
    Sep 2021
    CT
    Is there a way to test it?
    Yes, it has a fuse. And there should be 2 red wires to it. Those are power in and out. Just hook the ones that go to those to each other instead of that relay.
    Sep 2021
    CT
    Ill check it out later, Thx
    Sep 2021
    CT
    I tried bypassing the relay and that did not work. By any chance would the "grey box" from a 96 gti work on a 96 gtx?
    NO. You DO have the correct DESS lanyard? And have you tested the DESS post?
    Sep 2021
    CT
    That is a good question, I have (2) lanyards and (2) DESS posts. I do not know if they work.
    Sep 2021
    CT
    Am I correct in thinking that the lanyard is programmed to the DES post? If so can I try a different lanyard and DES from my 96 GTI that I know works?
    No the MPEM is programmed to accept the lanyard, it will only accept lanyards that are programmed to it.
