1996 Seadoo GTX Im at a loss - Page 2
Results 11 to 17 of 17
    Sep 2021
    CT
    Re: 1996 Seadoo GTX Im at a loss
    So the DES post is the switch and the lanyard programmed to the MPEM allows the switch to open or close the circuit.
    The DESS post has a magnetic reed switch that completes a ground circuit for safety. It also has a data wire that the MPEM uses to 'read' the serial number on the lanyard. IF the lanyard is recognized by the MPEM then the MPEM allows a start.
    Quote Originally Posted by TLuke*2021! View Post
    So I swapped out the MPEM, not knowing if this one even works. I checked the connections, checked the fuses and still nothing. I have power at the starter solenoid, I can jump the solenoid and the starter will engage. When I press the start/stop switch nothing. I don't have any power going back to the solenoid. No click, no beep, nothing on the gauges either. My head is spinning on where to begin.
    You will not get power to anything without the correct lanyard or having a lanyard programmed to the new MPEM. I AM NOT SURE HOW MANY DIFFERENT WAYS I CAN SAY THIS.
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Sep 2021
    CT
    Wow, I don’t think my questions warranted capital letters in your response but if it makes you feel better so be it. I do appreciate your replies. I’m just trying to figure this out.
    The way this forum usually works is this.
    1. Post asking for advice
    2. Ignore advice given
    3. Post again asking for more advice
    4. Repeat as often as necessary
    Sep 2021
    CT
    Lol... ok, I got it now..
