about done with this thing 96xp - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    May 2020
    Minnesota
    Re: about done with this thing 96xp
    How about if your looking to buy, say a 96xp, what are the signs that the seals are going?
    Engine smokes on startup I suppose?
    Quote Originally Posted by rotarypower101 View Post
    Do you find the higher viscosity oil doesn't leak into the combustion compartments? How do you know it has oil in there at any later point in time? What kind of service interval do you use to check its level, or top it back up?
    I assume if the seals are not operating properly it also allows the bath oil to be sucked in depleting the bath compartment and counterbalance shaft?
    The thick gear lube does not leak into the cases. You can hold a flashlight under the tubing and see the lube in it. I have maybe added 1 oz to my son's the whole time.....like 5 years!
    Quote Originally Posted by 95xprider View Post
    Engine will smoke BADLY on startup. Can also foul plugs while riding in a single day. Most commonly hydro locks the engine with oil over winter storage.
    Jul 2008
    Tea SD
    Got crank bearings in bypass. Backfire backfire , brand new plugs. Now I got this going on.......see video
    Now the carb sheet said 1.5 turns out if on 96xp, New carbs have accelerator on them. Is that wrong?? High side all the way in......
    https://youtu.be/l-MGHD5dOFA
    Oil on plugs already
    1996 Seadoo XP stock
    Put a volt meter on the battery and watch the DC voltage while it's running. What does it do?
  6. #16
    Jul 2008
    Tea SD
    what will that show me? did you watch the video? its not really running....
  7. #17
    A bad voltage regulator will cause one to act like that......it confuses the ignition system.
