Help Spark at end of start cycle
Results 1 to 10 of 12
    Sep 2019
    Scotland
    I am sure this has probably been asked before, but my circumstances are as follows:
    Kawasaki 750SX 92(ish)
    Replaced Coil
    Plug Caps
    New Plugs
    New Bendix
    New Stator
    Checked Starter button for continuity and earth - All OK
    Ski was running last summer, towards the end of a run it cut out in deep water, then wouldn't start again. Stripped the e-box to check all connections, stripped front end off to check pick up and stator, re-put all back together and turns over strong and occasionally fires up, however spark is only as I release the start button on both plugs.
    I am getting really frustrated as I cannot think what this could be after the amount of money and time spent on this, so any help advice would be greatly appreciated.
    Re: Help Spark at end of start cycle
    Make sure your battery is not dropping out too much voltage while cranking.
    If that's good you can try baking the cdi in a countertop oven at 200-250 degrees for about 20 minutes. That trick seems to have about a 50% success rate. If that still fails then you probably will need a cdi.
    What kind of stator did you put in the ski
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    "spark is only as I release the start button on both plugs."
    Bad CDI
    Sep 2019
    Scotland
    Thanks for replies
    Stator was brand new, for my make and model.
    Is there anyway to test the CDI or any other symptoms that would indicate CDI is gone. Don't really want to fork out the cash for a new CDI at this stage, already spent way too much on this for what it's worth.
    May 2005
    Right here
    Bad CDI
    Not always. A croaked coil on a stator can do this as well. Been there, done that.
    Changes aren't permanent, but change is.
    Riverside, CA
    6
    That is common on Kawasaki engines. It sparks just as you let off on the
    start switch, or you push the start switch and it sparks only once.
    Is your stator new (but not oem Kawasaki) or used?
    Perform a ACv test on the stator.
    Fully charged battery, Spark plugs installed, ground the plug
    caps to the cylinder head nuts or the e-box, leave the connectors
    connected, lanyard in place (if you have one), crank over the engine
    and measure each pair.
    Red to purple =
    Red to Black =
    Blue to green =
    Bill M.
    It wouldn't hurt to test the spark plug wire cores without the caps
    for 3.5K to 4.7K ohms
    Riverside, CA
    6
    (1) Make sure your battery is not dropping out too much voltage while cranking.
    (2) If that's good you can try baking the cdi in a countertop oven at 200-250 degrees for about 20 minutes.
    If the battery is low the JS750 might have problems cranking?
    The JS750 is a magneto-cdi, no battery ignition.
    That is a great test if you have a running engine that looses spark
    intermittently or after 20 minutes or so. But my preference is heating
    the stator first with a heat gun.
    CDI is tested with very last, process of elimination and then a
    peak dc voltage test on the primary wires to confirm if the cdi
    is capable of creating a spark. 150v or greater.
    Bill M.
    Heat and vibration kills electrical parts, so the stator is #1 on
    that list, the ignition coil (heat). Kawasaki spark plug wires are
    brittle and break (more common on the 650, 750 sit downs).
    Rust is another possible cause for ignition problems on the stator
    or coil. Bad front cover or starter motor o-rings.
    Riverside, CA
    6
    Myself, that was a repair method not a diagnoses tool?
    You have mentioned that before right?
    Sorry for the confusion
    Bill M.
    Yes, a possible repair........ it's an trick I learned from an old school repair guy. NOT a diagnosis, just a 'hail Mary" if you find a bad cdi.
