1996 gtx
Results 1 to 9 of 9
Thread: 1996 gtx
    Sep 2021
    CT
    1996 gtx
    So another project.
    1996 GTX, grey box and wiring has been pulled out of the ski. Previous owner purchased another complete unit. Is their a way to test the unit or should I just connect everything and see what happens.
    Sep 2021
    CT
    Re: 1996 gtx
    The unit being the grey box, CDI etc...
    Re: 1996 gtx
    You can connect it all up but unless you have the correct Lanyard for that MPEM you will have to have one programmed to it before it will key up and be able to check things out, luckily on those models the entire box is connected with multi-connectors so it's pretty simple just make sure to connect the wires with the same colors on the mulit- connectors
    Sep 2021
    CT
    Re: 1996 gtx
    Is the dealer the only place to get the lanyard programmed?
    Re: 1996 gtx
    Quote Originally Posted by TLuke*2021! View Post
    Unless you can find someone with a Candoopro or a handheld programmer
    Sep 2021
    CT
    Re: 1996 gtx
    ok, Thanks.
    Sep 2021
    CT
    Re: 1996 gtx
    Well,I tried hooking up the MPEM but no luck. Should I start with getting power to the grey box first.
    Sep 2021
    CT
    Re: 1996 gtx
    So I have power to the starter solenoid, when I jump the solenoid the starter engages
    Sep 2021
    CT
    Re: 1996 gtx
    Does that mean the solenoid is bad?
