Kawasaki JS 550 sx rebuild
    Feb 2014
    Rhode Island
    I just picked up a 1990 550sx with low compression in owner cylinder. Previous owner stated they had overheat problems prior to letting it sit in storage. I tore into the motor and the pistons and cylinders don’t look awful but I noticed the head has been milled. I don’t want to run this head again because it looks like it was milled too much. I have a nice 440 head and wondering if I could run this head on it?
    thanks in advance
    Re: Kawasaki JS 550 sx rebuild
    440 head is a no go combustion chambers are way too small, I have some good stock 550 heads if you need one.
    Feb 2014
    Rhode Island
    I have a used set of pistons and cylinder that were removed from a running ski years ago. The crosshatch is still visible in the cylinder. Wondering if I should hone the cylinder or would I be good to go as is?
