ZXI 1100 ignition switch problem
Results 1 to 6 of 6
    Jun 2022
    CA
    MY switch is damaged I read that on the 4 wire harness, if I jump the 2 reds together and the 2 remaining black and whites together the start button should start it, well that didn't work nor just the 2 reds together either. Can I get a little help here on the correct way to bypass this switch please?
    Re: ZXI 1100 ignition switch problem
    I've always just left the switch and gutted the little magnets and springs out of it. Then you can always just turn it by hand
    Jun 2022
    CA
    what did you use to dig them out?
    Once you open the switch, they will just fall out. Then clean the contacts and put it back together.
    Jun 2022
    CA
    I don't have to take the switch out do I?
    You most certainly do unless you are Harry Houdini
