1989 Waverunner Fiberglass help...Recommendations - Page 2
Results 11 to 13 of 13
    May 2022
    Texas
    Re: 1989 Waverunner Fiberglass help...Recommendations
    thats why i'm gonna try the proglas...seems to cover both grounds with smc and fiberglass...epoxy based...says it has short glass strands already in it...instructions say you can also glass cloth/mat it also...we'll see how it goes
    If it's epoxy based it will work fine
    May 2022
    Texas
    ok...here's my result....man it was a trying experience but i'm happy with what I did...you can see in sequential pictures the process
    pic 1 is how it looked after i got all the sticker and adhesive off
    pic 2 is after I cut the hole/rot out with my Ridgid oscilalting tool...I cut all of it at an angle
    pic 3 is how I decided to build up to fill the hole...I mixed in some 1708 mat glass with the Pro-Glas and basically just sanded the underside with my fingers...60 grit sandpaper...so the Pro-glas would adhere to the underside good...it did...I just filled the underside outer edges about 1 inch in with that and built it thick...used it as a base and just put more filler on top mixed with some 1708...it seems to hold well...pretty damn hard
    pic 4 is the mostly final result...a few minor things to do
    the sanding was the pain...over and over trying to fill small air bubbles/pockets...there are some in the final picture but nothing I'm concerned about...the small cracks.scratches on the side I mostly just sanded flat...a few needed some filler but it was a non-issue in terms of importance...I think the primer/sealer will fill in the rest...now what to do about the paint...we'll see
