trying to clean up soft plastic... need some suggestions
Results 1 to 6 of 6
    Jan 2022
    IN
    I have been fixing up a couple of old Waverunners that run great, but could look better. I am looking for some suggestions on how to clean the handle bars... see the picture. The stuff I use on my boat isn't touching it, but my boat has also never looked like this.
    Re: trying to clean up soft plastic... need some suggestions
    All I see is a grey circle with a minus symbol in the middle.
    Jan 2022
    IN
    Trying again...
    May 2005
    Right here
    Try a heat gun (carefully) or hair dryer
    Changes aren't permanent, but change is.
    That is not going to clean up, sorry but I am being honest here , your best bet is to spray it with vinyl dye, follow the linky thingy below, you may want to go with something darker than in the link
    https://www.overtons.com/sem-marine-...E&gclsrc=aw.ds
    Yep a re-dye is probably the best bet.
