1996 zxi 1100 just 1 spark when starting?
Results 1 to 10 of 20
    Jun 2020
    NC
    Having issues trying to get ski started. Great compression, has gas.
    I put a spark tester and I noticed that it would only do one spark (i see through the clear plastic on the testor) as I start the jet ski. It occurs in all 3 cables. It will start every now and then but rarely. Is this normal? Can't imagine since it you would think it could never start. Any idea what's wrong? And thx for bearing my ignorance!!
    Re: 1996 zxi 1100 just 1 spark when starting?
    Check your battery voltage while cranking it over. Look for how much voltage drop you have.
    Post falls Idaho
    Check inside box for water intrusion from broken plastic wire mounts on box ?
    also the plug boots.. the wire can corrode at the ends sometimes.. you can cut them back a little and use some dielectric grease
    Dec 2014
    SRQ FL
    1 spark only = cdi
    Jun 2020
    NC
    Thx for all the replies! My fear is the cdi. So $$$ prob not worth it on a 26 yo pwc.
    The voltage did drop. I switched batteries and same thing. What would that be from? And thx again!
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    SoCal
    Open up the Ebox and have look. Could be tour rectifier under the CDI.
    Post falls Idaho
    Have your cdi , need the kawi part number
    Dec 2004
    SoCal
    The 96 ZXI CDI is 21119-3745.
    Jun 2020
    NC
    bionic, i PM'd you. and yes the black box has 3745 stamped on it. thx ragged.
