New build 1100 Kawi Motor Middle Piston meld afer short time - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
    Dec 2010
    i dont know yet
    Re: New build 1100 Kawi Motor Middle Piston meld afer short time
    I installed a 3rd Pulse Line Fitting for that Fuel Pump.
    Those NGK BR9ES are the OEM ZXI 1100 Spark Plugs which i use.
    How can i identify the return restrictor ?
    Quote Originally Posted by Felix #86 View Post
    Its made into the carbs, check the clear fuel pump check valves on the carbs Yamaha carbs are known for crinckling , creasing those check valves, if they are damaged it will not pump fuel correctly or sometimes not at all.
    Dec 2010
    i dont know yet
    Well I rebuild all carbs before using them. They are now 45 minutes runtime like all other stuff.
    Did you replace the fuel pump check valves, it's the center cylinder , being that it can't be a crankshaft seal issue, either that carb is not supplying fuel correctly or you have an air leak somewhere
    Dec 2010
    i dont know yet
    Yes I rebuild all of them with oem mikuni parts. Engine is fresh build. Ski ran fine for 45 minutes gas tank was empty and then I refilled Start and hear the noise. I think the damage is because of I ran out of gas. In the tank was 1/4 inch of fuel maybe less
    It's possible I suppose but unlikely
    Dec 2010
    i dont know yet
    Looks like you have way more issues than a center piston, looks too lean across the board , that front cylinder seized also , what piston to wall clearance are you running on this ?
    Looks like that center piston died from Detonation, which means it is way too lean, I would start over with much larger main jets 130 minimum I might even go 135-140 because it's a lot easier to jet down till it runs right than try to jet up before smoking a set of pistons which you just did. Plugs are a lot cheaper than jugs.
    Riverside, CA
    6
    During that 45 minutes, how many times did the suddenly shut off,
    and then you restarted the engine.
    Bill M.
    Detonation Destroys, Preignition melts.
