Is this Engine Done?
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    PWCToday Regular 831's Avatar
    Jul 2019
    Ca
    Just pulled the top end off of a 1998 GTX Limited and the back end looks like it got smashed by blown piston debris. Is it worth rebuilding the top end or is this engine done from the shredded metal that went who knows where? Everything else seems ok. The sleeve itself isn't even that bad.
    Thanks in advance for the help fellas.
    Re: Is this Engine Done?
    Full teardown for crank bearing cleaning and inspection.
    Jul 2019
    Ca
    Yeah I got that far. The crank looks ok. No metal that I seen. I guess my question now is will this be ok to use performance wise with that chunk of metal missing? Thanks for your reply btw myself.
    Let's see some better pics of that area inside and out.
    Riverside, CA
    6
    Chunks of pistons can get wedged in between the rod and case,
    and sometimes crack the bottom case half.
    Turn the case half upside down inspect the bottom to see if it has
    been disformed by the rod.
    Bill M.
    Jul 2019
    Ca
    Thanks myself and wmazz. I will get some tomorrow after work of those areas. I didn't see anything that stood out damaged but I'm sure you guys have a better idea of what to look for.
    Dec 2014
    SRQ FL
    id retire it
    Jul 2019
    Ca
    I was able to snap some pics before I left the house.
    Jul 2019
    Ca
    Jul 2019
    Ca
    Wmazz the bottom of the case seems normal. No deformations or cracks.
    StuRat that was my first initial thought. But the crank seems fine. Could be wrong.
