1996 kawasaki 750 sts cdi question
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Jan 2021
    MA
    what is the best aftermarket cdi box. is the SBT one any good. also how do I test if my cdi is bad?
    Post falls Idaho
    Re: 1996 kawasaki 750 sts cdi question
    None
    Great timing on this! I'm currently waiting on a WSM cdi for an STS!! I'll let you know how it works out but I've used SEVERAL WSM cdi's for various models and they have all worked so far.
    Feb 2013
    NorCal
    See if the Zeeltronic cdi is compatible with the 750.
    Riverside, CA
    6
    Why do you think the cdi is bad?
    Heat and vibration kills electrical parts.
    Quote Originally Posted by rchpi36 View Post
    Through the process of elimination.
    Bill M.
    Jan 2021
    MA
    so what happened was I was coming off of wide open throttle when it died. tried to restart and would not, when I got it on the trailer I found that I had lost spark. so I ohm the coil and found the secondary side was open. replaced coil and had the same issue. I have ohm the pickup coil and it is within specs. so from my understanding the only thing left is the cdi box
    Riverside, CA
    6
    Kawasaki 650 / 750 coil wires tend to break. That was most likely
    your open.
    You are testing spark on both plug wires grounded? Because it
    is a wasted spark ignition, both spark plugs fire at the same time,
    but only if both spark plugs are grounded.
    How you lost spark is a little strange. Usually spark disappears
    after the engine warms up, maybe 10 to 30 minutes and it fails,
    and after the engine cools down for a few hours, it works again.
    I have been told by instructors, at manufacture clinics , etc that
    cranking over an engine without the spark plugs grounded can cause
    damage to an ignition system, but I have not ever seen an example.
    Maybe something failed when the coil wire broke??
    The manual is a little vague when it comes to testing the stator,
    but Kawasaki gave me specs for the small pin 750. Your big pin
    stator should be nearly the same.
    This is an ACv test for the stator and pick-up coil. You need to
    access the stator wire connectors at the e-box. Leave the wires
    connected and stick the multimeter probes into the back or front
    of the connectors and make contact with the wire terminals. Then
    follow the instructions and crank over the engine.
    Report your results.
    Spark plugs installed.
    Spark plug caps grounded to the e-box.
    Tether in place.
    All wires still connected.
    Set multimeter to AC volts
    Insert multimeter probes into plastic connectors to make contact with each wire terminal.
    Crank over engine and measure AC voltage. Max should be less than 100 acv.
    Pick-up Green / Blue =
    Exciter coil Red / Purple =
    Trigger coil Red / Black =
    Bill M.
    Jan 2021
    MA
    green / blue 1.1 Vac
    red / purple .8Vac
    red /back .9Vac
    so I assume with those readings I need a stator
    Red to purple while cranking should be 50 volts or more. Does either red or purple also read any ohms to ground?
    Jan 2021
    MA
    So I ordered a new stator. I removed the old one and saw it looks like it was rubbing. What would cause that?
