1996 kawasaki 750 sts cdi question - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    Jan 2021
    MA
    Re: 1996 kawasaki 750 sts cdi question
    can you replace the front and rear crank case seals with out splitting the case?
    No.
    Jan 2021
    MA
    so I found rtv on the end of my crank bolt. is that required for reinstallation? if so what type?
    No rtv. I use a dab of blue Loctite.
    Riverside, CA
    6
    Not trying to confuse the issue, but I like using a dab of
    silicone, 1211, or loctite 515 as a substitute for loctite.
    It works out as a stronger than blue loctite, and weaker
    than red loctite.
    A drawback to using these in place of blue loctite is that
    if you use too much silicone, you may fill the bottom of the
    bolt hole, and hydrolock the hole. When this happens the
    bolt or stud is bottoming out before it tightens (the flywheel
    or head for example). But I have seen bolt holes filled with
    blue or red loctite too.
    So, whatever you use, a dab should do.
    Bill M.
    And inspect bolt holes for excessive goop, before you assemble
    anything.
    Jan 2021
    MA
    UPDATE
    got the whole ski back together and it RUNS! thnx for the help. however I have a new issue I can only start the ski by jumping the relay with a screw driver. how do I test the relay and how do I test the start button?
