1996 kawasaki 750 sts cdi question - Page 2
Results 11 to 20 of 26
    Post falls Idaho
    Re: 1996 kawasaki 750 sts cdi question
    Bendix came apart , check , did you find a small balled up spring also ?
    That's not just rubbing....that's debris damage. Maybe something in the starter drive has come apart? Broken flywheel tooth bouncing around in there maybe?
    And on a side note, the WSM cdi seems to work like a champ.
    Riverside, CA
    6
    The bendix bushing is worn out too, or missing. It looks like the bendix
    may have been engaged while the engine was running.
    I suspect the front main seal is trash too.
    Bill M.
    Jan 2021
    MA
    I did find what was left of the spring. Where did that come from?
    Jan 2021
    MA
    UPDATE
    ordered new bushing, washer and spring. should I replace the Bendix?
    also is it worth removing my oil pump and going to premix even tho my oil injection pump works?
    Yes, replace the bendix! That's where that spring came from.
    Jan 2021
    MA
    is this the right flywheel puller tool? https://www.ebay.com/itm/12422732734...3ABFBMyt6c_qtg
    Post falls Idaho
    The spring retains the centrifugal weights of the bendix , the limiter washer will be broken , allowing weights to hyperextend and stretch spring till it breaks and get chewed up and balls up like what you found , flywheel puller is a big bolt
    Aug 2010
    Minnesota
    Your e-bay link to a $23 puller is very pricey. Just get a metric bolt at the hardware store. M18 x 1.5
    OLDGUY sez..... "The older I get, the better I was !
    Jan 2021
    MA
    is it work pulling the motor to make sure everything is done right or can it be done in the ski?
