Engine hoist options
    PWCToday Guru jd21476's Avatar
    Mar 2004
    San Diego
    Im going to be dropping an engine into a ski pretty soon and wanted to see what everyone is using to hoist the engine. Is a cherry picker my best option?
    2008 Seadoo GTI
    2006 Honda F12
    1978 Ultranautics Wetbike 65hp
    1985 Kawasaki JS550
    1989 Kawasaki JS550 (sold)
    1994 Yamaha FX-1 (sold)
    1978 Ultranautics Wetbike (sold)
    1996 SuperJet 760 (sold)
    1995 FX-1 (sold)
    2000 GP1200R (sold)
    Re: Engine hoist options
    Cherry picker of Harbor freight electric winch
    PWCToday Newbie revvinkevin511's Avatar
    Sep 2012
    Spokane, WA
    second the harbor freight hoist. I have mine mounted on a trolley rail and can roll things (even whole standups from one side of the shop to the other. Really saves your back.
    I have one mounted on a Gantry crane and I bought one that was mounted to a freestanding lift, I added some steel wheels so I can tilt it and move the whole thing around easily
    A chain or cable hoist hanging overhead works best. Cherry picker is great, BUT.....it seems like the legs are always in the wrong place and hitting the trailer wheels, then the lift arm is right in your way when you try to lean in and line things up etc. If it's a twin, I just pick it up and set it down in the hull by hand, they're only 60 pounds +/-
    Yep twins are not a proble till you get into seadoo 787's 951's and Yamaha 800's then you need a cherry picker or electric hoist
    Aug 2015
    Virginia
    Quote Originally Posted by revvinkevin511 View Post
    This sounds epic of a setup. Could you post a pic?
    Sent from my moto g power (2021) using Tapatalk
