550/750 ebox relocation
Results 1 to 10 of 10
    Iím posting this for a friend. He picked up a nice 87 550 with a small pin in it. The ebox is mounted on the front of the motor. The box keeps rattling loose even with loc tite. Is there a way to move the box to where the stock 550 ebox was? Conversion plate or something? I see the sell a whole brand new box to move it but its $400 from hot products! OUCH!!
    Thanks!
    Re: 550/750 ebox relocation
    Depending on what e-box he is running, we have a mount plate to put a stock 750 ss, ssxi, sts box in the place where the stock 550 was;
    https://watcon.com/products/conversi...x-to-550-mount
    If is it another type of box, you may have to make something your self.
    email watcon@watcon.com
    Please visit our web site
    Will it work in a 87 hull? The link says it needs a SX driveshaft to work.
    Thanks for the quick response john! Donít you sleep out there!
    PWCToday Regular TripleRRR's Avatar
    May 2010
    On the big fish
    It definitely works with an sx drive line and I'm pretty sure it would hit the bearing carrier on the older 550 hulls. It's a tight fit...rrr
    What do you guys typically do with this conversion? Leave the ebox on the front of the motor? Looks like his mount is homemade it looks like a giant shoe horn with holes drilled in it. Cant be factory!
    Quote Originally Posted by 550headache View Post
    Thanks for the quick response john! Don’t you sleep out there!
    Yeah, sorry our bracket only works with the SX driveline. (IE later 550sx, OR "IF" you are running a 750 pump conversion you will then run the X2 shaft and it will work). The "JS" drive bearing carrier is too large and the box will hit on it.
    Chicago / Portage, MI
    I ran a SX style smaller ebox, like Triple RRR shows above, in that position above the JS driveline for years. BUT, it requires the X2 shaft like John referred to above, and usually the further forward of two mounting positions if your conversion bed plate has them. Basically you make a plate which has the bolt pattern of both the stock box location and the 750 box.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    6M6, JD Intake Grate, 17/20, Coffmans Sizzler [49.1mph gps]
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    Aug 2015
    Kalamazoo, Michigan
    I got a little fancy and machined a spacer from another 550 box and squeezed everything into the expanded box. It wasn't easy but it worked and looks very clean. Hood seal just sitting, waterline routing was not correct at the time of picture, in case you were wondering.image000002 (1).jpg
    Mar 2005
    Michigan
    I just used a 1 inch thick cutting board and drilled it to the oem location, it held up for 6 years when I owned it, man i miss that ski, at the time it was the nicest one in Michigan that I.ve seen.
    PWCToday Regular PiranahIndustries's Avatar
    Nov 2016
    Chicago, IL
    I fab'ed one from a peice of sheet metal. Liked the location, but was a pain to remove the battery. Switching from studs to bolts may have made that easier. I'm parting out my ski currently, and can pull this if if you want it, either for inspiration or to use. PM me if you think it would help.
    1987 JS550/750 Conversion ďBig RedĒ
