Does anyone recognize this part
    PWCToday Guru jd21476's Avatar
    Mar 2004
    San Diego
    This was in a box of stuff that came with a Wetbike that I bought. It doesnt look like it goes with the ski12D6C384-0298-4F88-B5D4-03155ED9D921.jpeg but I cant make out what it is. Does anyone recognize it?
    2008 Seadoo GTI
    2006 Honda F12
    1978 Ultranautics Wetbike 65hp
    1985 Kawasaki JS550
    1989 Kawasaki JS550 (sold)
    1994 Yamaha FX-1 (sold)
    1978 Ultranautics Wetbike (sold)
    1996 SuperJet 760 (sold)
    1995 FX-1 (sold)
    2000 GP1200R (sold)
    Re: Does anyone recognize this part
    Well, it has a rotating flange and a shift arm.........some sort of gearbox.
    Oct 2013
    Ohio
    Could be some kind of PTO gearbox. Or perhaps a reverser or speed reduction for some kind of equipment.
    Is there a shaft we cannot see on the right side. If there is, what happens to the left side shaft when you turn the right side shaft? What happens when you move the shift lever.
    Any which way, it has steel (uncoated) parts.......not for marine use.
    Are there any casting numbers anywhere on it? It sort of looks like it belongs to an old lawn tractor.
