95 speedster 657X engine - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
    Re: 95 speedster 657X engine
    I was about to suggest this as I do on that guys 720 GTI thread
    jacksonville, fl
    Now I will try to remove the head off a saltwater engine.
    jacksonville, fl
    removed head and found signs of about 10 spots on top of the pistons that show where water was leaking in. could not see this thru the plug hole. about 6 bolts broke off as i was removing them. need to replace some parts. This is the problem with working on salt water engines.20220711_103405.jpg
    jacksonville, fl
    This is the not so fun part of working on saltwater engines, photos of the bolts removed to replace head o rings.20220720_183609.jpg
    That water probably fell in when you took off the head. Neither one of those piston tops show they were burning any water.
    jacksonville, fl
    Nope, that is referred to as the 'wash" pattern, or 'piston wash'. Fingernail sized pattern on the piston top right at the locations of the intake ports are just right. A little larger for a modified engine. That is where the raw fuel comes in and keeps the carbon 'washed' off the piston top. Water intrusion will basically steam clean the combustion chamber in the head AND the piston top.
    Riverside, CA
    6
    Quote Originally Posted by homebrewdoo View Post
    Port engine will rev to 7K and stay there, no problem. but starboard engine will rev to 6K+ but after a few minutes
    it will drop back to 4K, runs smooth, but won't run over 4K for a few seconds and than will go back to 6K for a for a
    minute or so and will do it over again.
    On smooth or choppy water?
    Is it running at 4K, then catches a little air in the pump, and
    gets 6k for another short period?
    Why do you have a 65gr spring, and do the carbs pop clean
    at 28psi and hold near 24psi, or does pop at 28 and leak down
    to something between 10 to 20psi?
    Those carbs have a tendency to run rich, and are sensitive to
    spring changes.
    It is a good habit to test pop-off while disassembled, and after
    each carb has been completely assembled. Pop-off should be the
    same.
    Were the needle and seats new, or used and you replaced the
    o-ring on each seat?
    Bill M.
    I recommend you find an EDM broken bolt or tap removal service.
    I have not ever tried an edm shop before, but those broken head
    bolts will be difficult to remove. Hopefully the cylinder bolts do not
    break too.
  9. #29
    if you had water intrusion the tops of the pistons and combustion chambers would be spotlessly clean, almost like they had been pressure washed, the steam created by water in the combustion chambe steam clean everything.
