Personal watercraft water temperature database
Results 1 to 10 of 17
    This is something I have been thinking about for a while, you think your ski is running hot, but how do you know how hot is it supposed to run ? I realize there will be some variances in temps as they come in from different places with varying water temps this time of year, also on some models like Seadoos worn wear rings would skew the results but if we get enough info we can get a baseline to work off of and at least get an average.
    I am going to post up temps recorded with a non contact infrared thermometer on skis I test run, hopefully some other people will do the same, that way we have a database to work off of, infrared thermometers are fairly cheap, I just bought a Fluke meter off of Ebay for $35.00 shipped.
    Post up your findings here following the style below and I will compile the list and update it as necessary. Temp reading taken at the front of the head but I did take it in several places they were pretty much consistent . Temp taken after running the ski wih it in the water idling. I will start with the one below and I will add two more today:
    2006 Seadoo GTX 4tec 155HP 184 degrees
    Re: Personal watercraft water temperature database
    2006 Seadoo RXP 4TEC 185HP 186 degrees
    2006 Seadoo RXP 4TEC 185HP 183 degrees
    All of the above are closed loop cooling systems, we can assume 180 degree thermostats by the temp readings.
    Posted by QUINC
    here is mine:
    701cc engine in jetmate:
    Cylinder temps where around 130-145 while idling/cruising and only 115-119 while running at full throttle. using infra red gun.
    Someone PMed me and asked if my Fluke was accurate , that theirs was off 8 degrees , first question how would you know if it was off 8 degrees or not, second question is does it matter, 8 degrees one way or another is a variance, something running 191 degrees or 175 degrees when it is supposed to be running 183 really would not concern me that much for the purposes of this database, if we get enough readings we get an average and a ballpark temp of what stuff is supposed to run at and rule out margins of error.
    Dec 2006
    Mesa AZ
    If you splash water on the cylinder and it steams, you're too hot. That's all I got.
    '96 Suuuperjet: 84mm 61x, ported, B-pipe, Dual 44's, Newmiller head 220psi w/girdle, Skat big hub, footholds, AMG green hell mango matte.
    Polaris carb AND ficht with thermostat in place....130-140* operating temp.
    size model and year please and I will add it
    The one I just tested wan an '03 MSX140.....1200cc
    But I've also tested a Virage Txi , Genesis carbed and Ficht ,and a pro1200 and several Fuji 750 & 780 machines.....they all run in that temp range with factory thermostat still in place.
    Cylinder temps where around 130-145 while idling/cruising and only 115-119 degrees while running at full throttle.
    '03 MSX140.....1200cc 130-140* degrees
    Polaris Vrage Txi , Genesis 1200 carbed and Ficht 130-140 degrees
    Polaris SLT-SL 750 -780 140 degrees
