Fx140 HO Oil Pump Driven Assembly Gear dowel pin?
Results 1 to 2 of 2
    Nov 2021
    tulsa, ok
    I am putting together a Fx140 HO sourced w parts from EBay. Iím ready to put the PTO cover on and I have all the gears and simple alignment pins. Can someone tell me if there is supposed to be a pin that fits into the end of the driven gear pictured for the oil pump? It seems to mate up to a stand/protrusion on the lower crankcase to keep it from sliding out of place, but the inner diameter of the driven gear and the crankcase stud are not the same. The service manual drawings online donít show a dowel pin but Iím uneasy about it. Thanks!! 0F1E95D5-0AF3-43AF-8232-774442EA1BC5.jpeg
    Nov 2021
    tulsa, ok
    Re: Fx140 HO Oil Pump Driven Assembly Gear dowel pin?
