Reduction drive gear bearing removal fx140
    Nov 2021
    tulsa, ok
    Question Reduction drive gear bearing removal fx140
    How do I this bearing labeled 20 out of here? I removed the Circle clip but not budging it.
    Nov 2021
    tulsa, ok
    Re: Reduction drive gear bearing removal fx140
    I removed oil pump and can’t access from the back side to press it out. Used part I bought has surface rust on the bearing so I’d like to replace before putting this back together.
    Jan 2006
    Florida
    Use a slide hammer bearing removal tool. I remember we had one at our dealership.
    You need a "blind" bearing puller. You could also try heating the area all around the bearing with a propane torch. The aluminum will 'grow' maybe enough to release the bearing.
