Seadoo 1165cc triple port 8mm stroker
    Frequent Poster scensor's Avatar
    Jun 2013
    Greece
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Re: Seadoo 1165cc triple port 8mm stroker
    Question regarding Photo #10 of the Exhaust Port:
    At the Bottom of the Exhaust Port, there is a "Step" caused by the Sleeve to Cast misalignment. Did the Sleeve get ported & blended to the Cast or is this how it is currently running?
    I ask because a "Step" will reduce Flow Performance...
    Jun 2013
    Greece
    So great question both my 6mm and 8mm triple ports have it. And this engine specific came like this after miller changed sleeves. No it’s not a mismatch, it’s like this due to the extra ports won’t create enough pressure in the c. Chamber thus they make main exhaust with this at bottom side to stop loosing lows. Highs you won’t loose any rpm from that. And also due to the stroke if you remove it piston skirt won’t cover that spot. Due to the 4mm piston going higher.
    Nice looking engine!
    Did you have the 8 (long) cylinder studs custom made, or was that
    something Miller made?
    Quote Originally Posted by scensor View Post
    IMO, this is more important. All kinds of problems occur on reed
    engines (depending on the engine) if that gap is too big.
    But the miss-match of the piston @ bdc to the exhaust port (sleeve
    height) is something Kawasaki featured on the 1986 KX250. But in this
    case (KX) the entire exhaust port was shifted upwards ~4-5mm.
    Are those Boost Bottles (connected to the intake) in the picture
    2nd from the bottom?
    Jun 2013
    Greece
    No these are miller made studs !!!!
    Finding new studs for the PJS Super Cylinder was difficult
    (impossible), I thought if they were custom made you might
    have a source (vendor) for other studs.
    Resident Guru 800X-4rider's Avatar
    Feb 2009
    Wrightstown,NJ
    Any idea on power?
    Jun 2013
    Greece
    Depends on pipe, compression i run and fuel
    low to 210 up to 240
