Brought home a 5th ski
    Frequent Poster aquanut's Avatar
    Sep 2013
    Delaware Coast
    I just had a buddy give me his 97 Polaris SLTX 1050 with trailer and title because he's frustrated with it , It runs but bogs he said and he took it to a shop to no avail , Its got a new black tip seat cover and handle bar cover , solas impeller ,ocean pro ride plate , a new set of carbs plus the original set , new in the box SBT upgraded stator ,new steering cable, SBT cdi box ,new power packs he said (not sure what that is) voltage regulator ,solenoid relay and a small trickle charger and some new spark plugs So i'll read about them and tinker with it some to see if i can get it right.
    93 Kawasaki TS 650
    92 Kawasaki TS 650
    92 Seadoo XP 587
    84 Kawasaki JS 550
    Re: Brought home a 5th ski
    Start with compression check. Don't worry if the rear cylinder is lower than the other 2, they came that way from the factory. Next, I would test that SBT stator. Aftermarket stators are VERY hit and miss.........mostly miss!
    Sep 2013
    Delaware Coast
    93 Kawasaki TS 650
    92 Kawasaki TS 650
    92 Seadoo XP 587
    84 Kawasaki JS 550
    Sep 2013
    Delaware Coast
    And thanks for the info ,I'll check it all out.
    93 Kawasaki TS 650
    92 Kawasaki TS 650
    92 Seadoo XP 587
    84 Kawasaki JS 550
